928 Forum 1978-1995
Sponsored by: 928 Specialists
Twists
Old Jan 7, 2013 | 01:43 PM
Dadddio's Avatar
Dadddio
Default Twists
I was thinking about these.
Would they fit an '86?
Stock OEM Porsche Turbo Twist wheels (not aftermarket) with tires mounted.
Front set are 17" X 7", 55mm offset, 130mm bolt pattern
Rear set are 17" X 8.5", 50mm offset, 130mm bolt pattern
Porsche center caps are included
Old Jan 7, 2013 | 01:47 PM
DougM's Avatar
DougM
They will fit, however, I would upgrade to 18s if I wanted twists. They have more tires to choose from and they are wider, which the car can handle.
