928 Forum 1978-1995
Sponsored by: 928 Specialists
Ignition Switch Tension Spring
Old Jan 4, 2013 | 06:19 PM
leperboy's Avatar
leperboy
Default Ignition Switch Tension Spring
Part 928 613 223 00 is the ignition tension spring. While I had my pod out today, it fell out and it is not clear to me where it goes or how it fits. Any photo or description of where it sits in relation to the switch and what its two arms press against will be really helpful.
Thanks,
Matt
Old Jan 4, 2013 | 06:49 PM
rexpontius's Avatar
rexpontius
If I'm not mistaking, it's supposed to hold the electrical part of the ignition switch pushed to the mechanical part, it slides over the back of the whole thing.
Kind of hard to explain by typing, but very easy once you see it, it just slides on.
Old Jan 4, 2013 | 07:54 PM
leperboy's Avatar
leperboy
Thank you! Once you said that, it made sense. There are two bumps on the arm that holds the key mechanism. The ignition switch plugs into the back of that. The retaining spring arms slide over those two bumps and then wraps around the back of the ignition switch.
Matt
