928 Forum 1978-1995
Sponsored by: 928 Specialists
Throttle linkage question
Old Jan 1, 2013 | 04:09 PM
Harvey928's Avatar
Harvey928
Default Throttle linkage question
How hard is it to replace the black plastic piece that is in the red square? How expensive is that piece?
Harvey
Old Jan 1, 2013 | 05:43 PM
Kiln_Red's Avatar
Kiln_Red
Here is a link for the PET blowup. You can see it in the illustration for both the throttle linkage and Bowden cable. In either case, I don't see it listed. Maybe Roger can help.
Old Jan 1, 2013 | 05:54 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
In my estimation it is not possible unless you cut the cable and then solder it back together. May be easier to replace the cable - used of course. I bought a new one to replace it.
Old Jan 1, 2013 | 07:44 PM
Tom in Austin's Avatar
Tom in Austin
I need one of those too, Harvey. If they are available as a replacement part, Roger will know how to get them!
Old Jan 2, 2013 | 06:19 PM
frustrated's Avatar
frustrated
The outer cable is bonded to the inside of the hex nut so comes attached when buying a new cable
