Looking for a fanfare picture
My '88 (not '84 - typo) S4 has only one horn - so it can only go beep instead of having the dual high-low "fanfare" Porsche describes ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Anyway, it appears that the end mounting hole in the bracket is fractured and the whole second horn assembly is therefore missing. The remaining horn support seems to be twisted but is still mounted. Most likely this is impact damage.
Does anyone have a picture handy of the original instalation. Thanks.
Thanks BigAl1. Unfortunatley it looks like the horns for the '80 are very different to those of the '88 - compare 80 to 88.
This is what mine currently looks like:
![](http://i1229.photobucket.com/albums/ee470/msumnersmith/IMG_2486_zps5f86d3b4.jpg)
and
![](http://i1229.photobucket.com/albums/ee470/msumnersmith/IMG_2487_zpsde01f60c.jpg)
You can see the broken end of the bracket and the hanging wiring connectors for the second, missing horn (and the broken support tab to the left),
Does anyone have a picture of my horn style please?
and
Little kids are very observant, or at least this one is!
Martin, look on this page, there is a picture:
http://members.rennlist.com/v1uhoh/underww.htm
The horns are a bit different, the one you have is the correct model, just need one more, the low or high picthed one. Don't get too excited about the "fanfare" it's just two horns and a rather disappointing sound.
Electron Wrangler
Well you have the mounting pylon that bolts to the frame rail - good. I agree the stock horn "fanfare" is rather weak - I'd recommend NOT getting the other stock horn and instead get a pair of Hella Supertone horns - louder (118 dB) similar in size & mounting - much better result - not that expensive ~$60). Electrically both connect to the exact same horn feed wires in parallel. Do get rubber boots for the connectors (like stock) it gets wet in there..
Alan
Alan
Alan
Alan
