Cobra Heat Exchanger Mounting
Well, I finally got off dead center and jumped into the uncharted waters of the Heat Exchanger (thanks Hans) placement and install. Any suggestions, warnings, recommendation and pictures from you guys will be greatly appreciated.
First, I got the cooling flaps out. Can or should any of the frame or plastic air flow directors be reused ? Doesn’t seem like there will be room.
Hans sold be a prefect Cobra HEX similar to Tony’s (I think). From your picture, Tony, it looks like you mounted it horizontally near the front and towards the top with a clamp/ allthread arrangement. My HC already has two mounting ears that would make a similar install pretty simple and easy. Obviously, the way your car runs this is a good way to go. Anything you would do differently?
I know several other have this same HEX. Did you mount it the same way, etc.,etc.
Thanks for all your help and I hope everyone has a GREAT holiday season.
Ralph
Ralph
