Daytime Running Lights (DRL) LED Modification?
I put the relay in my 1990 s4 and the DRLs work great
Take a look at the Philips DRL site. You can upload a photo of your car and see what the LED DRL will look like
http://www.daylight-led.com/cars/
Administrator - "Tyson"
This is the main problem with LED's on cars that do not have HID lights.
Warm white LED's will match the original 928 lights better, assuming they can be found in an automotive application.
I have warm and cool white LED's as part of the Christmas decor.
Electron Wrangler
I think the stock DRL system and many others like it are just stupid...
Putting the fogs on without any rear lights leads to folks driving around at dusk/night thinking they have lights on when they really don't...
There are enough morons about who drive at night without lights - without encouraging more of them .
I think all DRL implementations should include marker lights as well.
Alan
Alan
Alan
Alan
Electron Wrangler
On a 928 the dash lights are always on with the ignition - not just when DRLs are on - But I agree that doesn't help either...
Alan
Alan
Received 1,238 Likes
I don't think my dash lights come on when the lights are off.
What I know for sure it's that they come on when I turn the switch to the first position (parking lights) with the green signal that tells me that the lights are on.
Electron Wrangler
Older S4's and before may not do this - but I believe all digidash do - that should include the '91.
Its realy not so obvious in daytime - but sit in the car at night and turn the ignition on...
Alan
Alan
I was thinking more about it during lunch time and you're right...
When I turn the lights on the gear indicator goes darker, so it has to be on (brighter) when close.
You're right Alan, not so obvious in daytime.
Sorry, my bad.
Sorry, my bad.
I never used the fog lights, so I installed a set of LED H-3's in place of the Halogen H-3's and installed the proper relay (it was OE for the lucky guys up north of the border in Canada). The LED's wouldn't produce much light in case of fog, but it is plenty to show up as DRL's. I also have protectant polymeric covering on my fog lenses, so didn't want too much heat build up with the Halogens.
That relay is OE on VW's and Audi's. Readily available for about $5 on eBay.
Gary
Gary
I put in the Audi relay as well and it works great. I think it's a nice safety improvement for those of us with darker (harder to see) cars.
And there's no way I'll forget to turn on my headlights. They're a signature feature of the 928, and watching them pop up is still a special event for me...
