Cruze Control problerm
Ok with luck this will be an easy fix... So im hopeing ![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
My cruze control works but when i set it it speeds up 10 mph. The coast doesnt seem to work and stay set were i want it to. if i slow to a speed that is 10 mph below the speed i want it will set and speed up and hold fairly well.
Any suggestions??? I really dont know ware to start with this one.![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
The Cruz Controller is located in the Right front fender just behind the front wheel.
If you look at the brake booster there are a two small vacuum lines that feed from the small blue check valve and go to a "Y" then into the fender.
I would check the lines for tightness and a leaks first as the Cruz controller uses vacuum to monitor throttle/load. I know a small vacuum leak will cause the set speed to decrease over time.
i will check into that. i know i have checked the vacuum line from boster to the a/c as i had a stuck check valve. but the cruze control seems to hold well after set it just does not set on the seed in which you wish to set it to.
