HVAC question...
I did some searching, and came up with a lot of info, but not specifically what I am looking for.
As many here know, my 84 Euro has the interior pretty much out right now. I put the center dash console back in, but not permanently. The HVAC controller and lock/ warning system are hooked up.
from time to time the blower motor will run when I turn it on and the ***** are in certain positions. I am not certain as to whether it is operating per design. I am pretty sure in fact that it isnt.
Anyway, Wally advised me to change out all the vaccuum related servos or what have you that are HVAC related and behind the console. I am wondering which ones should be replaced, and what they do precisely. Again, I have a general idea, and am more looking for a clearly defined locations and functionality. Pics would be hella nice also if possible. Since my car had no interior what so ever when I got it, I have been using the search function and asking questions to piece it back together.
Since heat / defrost is nice in the winter, I would like to get on it asap. I have foiund on ebay a bunch of different heater valves and such (like this one: http://www.ebay.com/itm/IMC-653-5400...7d902b&vxp=mtr)
thanks.
thanks.
Yes - just replace ALL of them - its easy now and cheap - once its all back together any that aren't leaking now will start to leak.. they are old dried out rubber...
Don't screw with used stuff on eBAY - it's also old dried out rubber.
If your actuators look OK and move OK...? JUST BUY THE DIAPHRAGMS FROM ROGER (ROG100),
Do however get a NEW heater valve (whole thing) from Roger also. A cheap aftermarket version could dump all your coolant while driving fast - not worth any savings.
You can find a manual online and see how the HVAC head controls are supposed to work - don't bother testing operation of anything functionally until after you update all the diaphragms. Do buy a Mity Vac (<$40) and test the actuator operations & solenoid bank for leaks.
Note that the default positions of the water valve and the defroster vent are open with no vacuum. Others are closed/fresh with no vacuum.
Alan
Alan
Follow the write ups: several pictures and detailed procedure. The ones I used are bellow:
http://dwaynesgarage.norcal928.org/1...0Procedure.htm
http://members.rennlist.com/pirtle/svc.html
http://www.nichols.nu/tip509.htm
http://jenniskens.livedsl.nl/Technic...5/MyTip594.htm
Or just pick up the phone & call Roger - tell him what year you have and he will know what you need...easiest way... and he's a nice guy worth getting to know - you will likely need to talk to him lots more...
Alan
Alan
alrighty then. I always feel crunchy about calling people who I do not know and asking the questions in the middle of their day. At least here you guys can chose to ignore me.
Second Alans post... replace all diaphrams from roger.
If I can in a later date, there is specific vw's readily available in scrap yards that have same actuators...cheaper and can test in the scrap yard.
Wally also has an excellent write up on the HVAC system diagnoises.
I have the center and footwell diaphragms for $56.95 each. Not cheap because I rob them from another famous German car actuator but cheaper than buying from Porsche.
The defrost actuator is $46 and the recirc actuator is $28.
The heater valve is $22.75 and I recomend changing the valve to block hose at the same time.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
The heater valve is $22.75 and I recommend changing the valve to block hose at the same time.
Dennis
Hopefully I can get the hvac system working in this car (euro). it has an "aftermarket" wire going from the ac fan to the ac pressure switch. So obviously something "Porsche" went wrong and got replaced with economy. The blower turned on the other day but only went on occaisionally, or maybe it was temp sensitive I dont know. But I know that the motor works... everything as far as ac controller is hooked up. Truthfully, the servos and such look pretty good, but for 225 or whatever, would rather have the opeace of mind associated with new ones. Maybe first I should get gas coming out of the pump though.
