87' Heatshield speed nuts/screws
Where can i find the speed nuts and screws used to secure the heat shields in an 87 S4? How are speed nuts categorized? I assume same as Metric/SAE.
I can probably find these at any local fastener place, i just need to know what i'm asking for.
McMaster calls them 'Clip-On Nuts' http://www.mcmaster.com/#clip-on-nuts/=kchq0k
Locally Ace Hardware has the best selection for me.
The OEM screws I never found (although you could use alternatives), however, you can still get them from the likes of 928intl of Pelican and they are relatively cheap.
Archive Gatekeeper
The metric sheet metal screws for the exhaust heatshields are all B5.5 x 16 screws, and go into a B5.5 speed nut.
The mcmaster metric clip-on nuts are all threaded for machine screws.
The correct screws for the heatshields (900.187.115.02) have a captive washer and are NLA from Porsche. Pelican supercedes to 900 187 115 01 but they are $5 each. 928Intl probably has a bucket of them. Greg Brown has a big bucket of replated ones but they typically only appear on your car when Greg is displeased with the appearance of the ones that were on your car when it rolled in.
Just to gild the lily, here are all the instances of speed nut in the 87-91 PET sheets, so you can see all the applicable sizes on an S4.
Code:
Sheet Pos Part Number Name Remarks Qty 201-15 39 999 507 003 02 speed nut 1 801-20 19 999 591 736 02 speed nut 10 801-20 - 999 591 736 02 speed nut 90- 8 801-25 4 999 507 003 02 speed nut 26 802-15 13 928 512 307 02 speed nut 6 807-00 4 999 591 590 02 speed nut 7 807-10 47 999 591 377 02 speed nut 3 809-00 6 999 507 029 02 speed nut 2 809-00 40 999 507 245 02 speed nut 1 809-02 33 999 507 245 02 speed nut 1 809-05 5 999 507 002 02 speed nut 2 809-05 15 999 507 002 02 speed nut 2 809-05 41 999 507 002 02 speed nut 2 811-05 42 999 507 248 02 speed nut 2 905-05 14 N 900 488 01 speed nut 2 905-05 14A 999 591 349 02 speed nut 4 907-00 13 N 015 429 2 speed nut 2 911-01 11 999 591 583 02 speed nut 16 813-30 12 E 999 591 368 02 "speed nut 4,2" 2 813-30 30 999 507 037 02 "speed nut 4,2" 2 813-30 44 999 507 020 02 "speed nut 4,2" 1 809-05 11 999 507 030 02 "speed nut 4,8" 3 802-05 24 N 902 689 01 "speed nut B 4,2" 2 802-15 17 N 015 429 2 "speed nut B 4,2" 6 802-15 32 999 507 229 02 "speed nut B 4,2" 2 810-05 16 999 591 797 02 "speed nut B 4,2" 10 20 999 591 873 02 "speed nut B 4,2" 2 22 999 591 787 09 "speed nut B 4,2 F >>92HS8 40080 F >>92HS8 49560 F >>92HS8 60065" 2 33 999 591 787 09 "speed nut B 4,2 F >>92HS8 40080 F >>92HS8 49560 F >>92HS8 60065" 2 801-05 30 999 591 348 02 "speed nut B 4,8" 9 801-05 33 999 591 699 02 "speed nut B 4,8" 4 802-00 15 999 591 485 02 "speed nut B 4,8" 5 802-10 5 999 591 699 02 "speed nut B 4,8" -89 3 802-10 8 999 591 699 02 "speed nut B 4,8" -89 3 802-10 12 999 591 699 02 "speed nut B 4,8" -89 2 802-10 15 999 591 699 02 "speed nut B 4,8" 4 802-10 18 999 591 699 02 "speed nut B 4,8" 6 804-05 28 999 507 348 02 "speed nut B 4,8" 4 801-15 12 999 591 487 02 "speed nut B 5,5" 16 801-25 20 999 591 487 02 "speed nut B 5,5" 15 802-05 38 999 591 487 02 "speed nut B 5,5" 2 105-05 38 999 591 571 02 "speed nut B 6,3" 2 403-01 25 999 507 003 02 "speed nut B 6,3" 1 31 999 507 003 02 "speed nut B 6,3" 2 903-10 5 999 507 034 02 "speed nut B 6,3" 2 813-10 9 999 507 003 02 "speed nut B 6,3 X 16" 1 804-05 35 999 591 242 01 "speed nut D = 4,0" 2 811-05 17 999 507 248 02 "speed nut M 5" 2 811-05 30 999 507 248 02 "speed nut M 5" 1 104-00 - 999 591 882 02 "speed nut M 6" 90- 2 801-25 19 999 507 048 03 "speed nut M 6" 2 904-00 - 999 507 246 02 "speed nut M 6" 1
What's to stop you from just using generic ones that have the proper dimensions and clip in properly to where they're supposed to?
I've got something in sets of 10.
5.5 x 18 with integrated washer.
5.6 U nut 10MM from center of hole to edge
$12.00 plus $2.00 shipping
