Is this Used PS rack usable?
I bought this used unit indirectly from a lister parting out his 1987. I was planning on swapping my seriously leaky rack as a winter project. Did not look at the rack too closely. That was my mistake. But now that I have I see that there is corrosion on the passenger side I need to now if I should go a different way.
There is no indication it was leaking. I did take some wet dry sandpaper to remove some of the corrosion before I took the picture.
See picture.
Thoughts?
See picture.
Thoughts?
If yours looks better, but leaks, you might consider swapping racks. If this one then isn't satisfactory, you now have yours out to rebuild. Otherwise, talk to Jeannie about using this one as a rebuild core.
