928 Forum 1978-1995
Sponsored by: 928 Specialists
4.7L Euro S LH dyno....WOW!!!!
Old 11-23-2012 | 11:40 PM
IcemanG17's Avatar
IcemanG17
Default 4.7L Euro S LH dyno....WOW!!!!
Took Seans #52 racer with a true Euro S LH engine......BUT only a standard L jet intake-injection.... Common 928 theory says that this highly underrated engine will be severely choked down by the AFM, smaller intake and TB....
Sean has a Euro S LH intake ready to install, but it needs a pricey MAF conversion....so I said why not test it as is....when we ran together last time it didn't seem down on power.... So off to the dyno I went....
While warming up Seans car around the paddock (NASA teen car control clinic) I noticed a Cessena taking turn 1 at about a 45' angle at maybe 150mph.....I thought that was odd....While we were getting the car on the dyno Speedtoys showed up....he was flying the Cessena....flew up to say hi!!!!
So we put it up on the dyno....tried a few runs in 3rd gear.....it spun up the dyno stupid fast and didn't make much power....5th gear was better...but everything was VERY lean.....scary lean....so we started adjusting the L jet AFM to add fuel.....after several more runs and settling on 4th gear....we get everything sorted.....
276whp-298torque
DAMN.......makes my lowly 243whp-257 torque on the same dyno so puny in comparison....I'm lucky its 250lbs lighter!!!!
Old 11-23-2012 | 11:55 PM
justaguy's Avatar
justaguy
Brian
Thanks for doing that today. I'm happy with the numbers. Next big test is door to door on track. Winner buys the beer.
Sean
Old 11-24-2012 | 12:38 AM
Landseer's Avatar
Landseer
Wow. Data speaks.
How, if you don't mind sharing, do you make those L Jet adjustments?
Old 11-24-2012 | 12:48 AM
danglerb's Avatar
danglerb
Very big numbers, about 20 hp more than I would have expected. Anything special on the exhaust?
That was the setup I originally planned for my US 83 5 spd, keep the US intake and FI, and use a Euro or Euro hybrid long block.
Old 11-24-2012 | 01:50 AM
IcemanG17's Avatar
IcemanG17
as always I (& Sean) are open books to 928ers.....
1: How did we add fuel...super easy...."clicks" on the AFM....so basically you reduce spring tension in clicks to increase fueling....or the barn door opens FASTER...so the L jet adds more fuel....this is also what I did on the Estate...worked great but took much more to get the Euro running right...13 clicks come to mind today
2: Exhaust: MSDS headers into straight pipe 3.5" system.....with flow through mufflers....exact same setup as my racer....(with 30 less HP :>(
Bottom line....it all comes down to who crosses the line 1st..... Sean and I have very similar cars...his has more power but is a bit heavier....mine has less power but is 250lbs lighter.... Hopefully we can produce some excellent video just before the 25 hour race....
Old 11-24-2012 | 01:59 AM
IcemanG17's Avatar
IcemanG17
Originally Posted by justaguy
Brian
Sean
Since I don't drink beer....I will settle on a "proper" bottle of wine at Casa for dinner!!! My choice of course
Old 11-24-2012 | 02:01 AM
Speedtoys's Avatar
Speedtoys
if all 3 of us can be on track at once...just timing/etc.
Old 11-24-2012 | 02:05 AM
IcemanG17's Avatar
IcemanG17
but we only have 2 928's the Friday before the 25.....assuming the weather is nice.....since I only have 1 set of rain tires
What are you gonna drive....the insane boosted monster....you will crush us in the straights.....BUT not in the corners
Old 11-24-2012 | 02:06 AM
Speedtoys's Avatar
Speedtoys
The 928 aint a track car...period. Next weeknd is supposed to be quite wet...it appears right now.
Old 11-24-2012 | 02:12 AM
justaguy's Avatar
justaguy
928 aint a track car? Wish some one would have told me that.!
Old 11-24-2012 | 02:15 AM
IcemanG17's Avatar
IcemanG17
well yours isn't
mine is....
Old 11-24-2012 | 02:17 AM
Speedtoys's Avatar
Speedtoys
MINE isnt...and FWIW, most of the racing market made the same decision..its possible...but it would be easier to do it for ME..if it was already an entirely trashed car..but still, Id me more likely to find my fun in a competative momentum car.
Old 11-24-2012 | 02:23 AM
danglerb's Avatar
danglerb
No Y or X? No cats?
I wonder why so lean? You would think over time the spring would get weaker, maybe a worn track on the AFM?
Old 11-24-2012 | 02:25 AM
Speedtoys's Avatar
Speedtoys
Kibort O pipe.
Old 11-24-2012 | 02:40 AM
IcemanG17's Avatar
IcemanG17
Originally Posted by danglerb
No Y or X? No cats?
Both racers have a Y pipe...since its a single system....however if I was running a serious motor 928 racer I would run a dual system.....since they make more TORQUE....and everyone knows torque wins races and HP sells engines...
Quick Reply: 4.7L Euro S LH dyno....WOW!!!!
