Who'd want a used timing belt?
Cleaning up the garage yesterday and found the belt Sean replaced back in March. I had a premature water pump failure and while he was in there changing it, he put on a new belt. The old one was installed in 2008 and had about 14K easy miles on it when the WP crapped out.
I hate throwing stuff like this away, so if anyone has a use for it, give a shout.
Team Owner
Hang that sucker on the garage wall so you show your your friends how big it really is.
I wouldnt use a used belt given the time it takes to remove the old part,
the old belt is like a used Rodeo rope, it may still look good but it has seen better days
Considering at TB costs about the same as a case of beer up here, I would always use a new one.
Keep it to threaten 911 owners. Tell them you will strangle them with your timing belt if they scoff at your 928!
