TT issue...input needed.
Anyway...I started the TT removaly a couple days ago and finally today got in out to see.
https://rennlist.com/forums/attachme...1&d=1353449164
I then measured the rod projection are the front of the tube.
https://rennlist.com/forums/attachme...1&d=1353449398
I then removed the rear coupler and TT bolts to seperate the TT from the trans. What happened was the tube slid out leaving the rod attached...not good as the bearings should be tight enough to hold the rod in place. Now i see why the rod was moving all over the place.
https://rennlist.com/forums/attachme...1&d=1353449593
After the tube was loose I turned it on end and the dampener FELL out. I removed the other 2 ( yes...just 2 bearings) with very little effort. This is all that was in the TT ....
https://rennlist.com/forums/attachme...1&d=1353449739
I NEED to know how this happened so it will not happen again...Is this the correct TT and rod for a 1989 s4 auto??? How many bearings should I have?? Here are details of the rod that I have.
https://rennlist.com/forums/attachme...1&d=1353449842
https://rennlist.com/forums/attachme...1&d=1353449888
Any help whould be very appreciated.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
From the pictures you have a rebuilt TT that used old bearing holders, old bearing inserts and the old vibration dampener. The only new pieces are the two incorrect bearings placed into the old bearing housings.
Up to 1987, 928 automatic TTs used a 25mm drive shaft with three bearing units and a vibration dampener from the factory.
Sometime in 1987 and up through the GTS models, 928 automatic TTs used 28mm drive shafts with only two bearing units and a vibration dampener in them from the factory.
This TT was rebuilt with an older 25mm drive shaft instead of the newer 28mm drive shaft which are more prone to shear fractures. This is a good thing. But the re-builder should have placed three bearing units in the TT when using the 25mm drive shaft.
As far as the vibration dampener, anything rubber will fail with age. This vibration dampener has come apart as many are doing due to their age.
Hope this helps,
In '88MY, the shaft diameter changed to a 28mm shaft with a neck-down to the same spline size where it enters the transmission. It is however generally acknowledged that the thicker shaft is inferior as the neck-down creates stress risers and those later shafts are prone to shearing in two.
Also, Auto has 2 bearings, Manual has 3 (both auto and 5-speed have the vibration dampener - except for Clubsport/SE/89GT models AFAIK).
I'd measure the length of your shaft.. if its the correct length for 80-95 (per the diagram below), I'd keep it.
Here's a handy pic by Erkka on measurements:
Code:
'78 -> '82US/83ROW 3sp gearbox, long TT, 25mm center shaft
'83US/84ROW -> '84 4sp, washers for front flex plate, short TT, 25mm shaft
'85 -> '88 Without front flex plate adjustment, still 25mm shaft
'89 -> '95 28mm thick center shaft
It looks like a mismatch of parts has been used on this installation.
WARNING do not let the driveshaft hang unsupported in the input collar of the transmission EVER...
I have 3 bearings in my 88.
You need a good used damper as well,
and you should consider pinning the ends of it after its installed.
Quite possibly you also need a new correct driveshaft
The drive shaft end you are showing has been forced into the rear coupler and now has dents from that encounter. These dents can manifest into a failure in the future since the metal has been compromised. Other than that this is a normal 25mm drive shaft that will fit in all year 928 automatics.
We do not advocate using another vibration dampener since they will fail, even if you try pinning it. Pinning might stop it from sliding around, but the heavy metal portion will still slop around and also ride on the drive shaft after it breaks away from its rubber holders, like yours did.
Our website has some more useful information on all of this information. We have invested a lot of time into looking at all the failures of the 928 and 944 drive lines which we have put on our website to help owners such as yourself.
Best regards,
