928 Forum 1978-1995
Sponsored by: 928 Specialists
TT issue...input needed.
Old Nov 30, 2012 | 05:30 PM
  #121
dcrasta's Avatar
dcrasta
Originally Posted by KenRudd
Fun sponge!
You are correct, not a heat sheild. After spending Sunday under the car trying to pin it down, I do know this:
1. It's intermittant.
2. It's coming from the very front, more in the front flex plate area ( But I realize that the apparent location can be deceptive)
3. I only hear it at stop or going very slow at idle.
4. Porken lift bars are worth their weight in gold.
I'll post on a new thread if it gets interesting..
The way I determined it was my Torque tube was to remove the inspection cover, then disconnect the 6 bolts holding the clamp to the flexplate. Then remove the pinch bolt and slide the clamp back far enough to give you a few CM clearance between the assembly and the rotating flex plate. Start the car and listen if the sound goes away its likely the torque tube.
The torque tube acts like a megaphone and will project its sound (and the sound will bounce around) make it extremely difficult to pin down the source.
Best of luck,
Hugh
Old Dec 5, 2012 | 06:41 PM
  #122
medipedicman's Avatar
medipedicman
Any updates on the TT?
Old Jan 20, 2013 | 07:23 PM
  #123
depami's Avatar
depami
Dean, got any pictures of this process?
Old Jan 20, 2013 | 07:24 PM
  #124
Dean_Fuller's Avatar
Dean_Fuller
1-20-12 update
TT was rebuilt using the bearings supplied by MY good friends here on RL weeks ago. Waited on some seals for the trans to get here and resealed what I could yesterday.
Did the MM and pan seal as I had these parts in my parts box for years now. NOTE TO SELF and thos that want to know....doing the MM with the drive train out is a mistake. Very difficult to get it all lined up as the motor wants to rotate with the TT out.
VERY close to pushing it back under the car! Want to make sure I don't miss something first.
Here is where I am. Will update as I complete. Hope to have it all done in 2 of 3 days.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 20, 2013 | 07:35 PM
  #125
Landseer's Avatar
Landseer
Dean, did you find the removal of carrier with transmission (and TT) awkward?
Old Jan 20, 2013 | 07:45 PM
  #126
Dean_Fuller
Not at all. I thought everyone did it that way till I read the manual.
Old Jan 20, 2013 | 10:41 PM
  #127
ammonman's Avatar
ammonman
I would take the few minutes to replace the soft portion of the vacuum line to the modulator now while it's easy to get at. My local import shop was out of the fabric covered hose so I went with silicone.
Mike
Old Jan 21, 2013 | 09:20 AM
  #128
depami's Avatar
depami
Got any pictures of the bearings themselves? New next to old? Being inserted into tube? Etc.
Old Jan 21, 2013 | 11:54 AM
  #129
Dean_Fuller
I did not take pics of the bearings before I assembled the TT. Wish I had.
Those super bearings are just that. They are so wide there is NO WAY they could ever titl in the tube which I think is a weakness of the stock. Even a little tilt would put undue stress on the bearings at least in my mind.
Hope to have more this evening.
Old Jan 21, 2013 | 11:55 AM
  #130
Dean_Fuller
Mike
Good idea...will locate some before the assembly is raised into place.
Old Jan 28, 2013 | 05:43 PM
  #131
Dean_Fuller
Update 1-28
Well she is running! Had a heck of a time filling the trans fluid. Also changed diff oil. Got everything back together and the trans SLIPS in all forward gears. Talked to Sean and he suggested adjusting modulator pressure. I gave it 2 full turns clockwise...and it shifts a small tad hard now....but no slipping.
No rattling now too so thanks everyone for the much appresicated help!!!!
This last go around...I replaced the TT bearings, Torque convertor bearings, Trans pump seal, motor mounts and oil pan seal!
I think before I drive too much I will get a trans shop to check pressure as I have no idea if its too high now. The modulator does have a very slow vac leak so I will need to fix that but its down off jack stands!!!
Old Jan 28, 2013 | 07:16 PM
  #132
medipedicman
Congratulations buddy!!! Good job.
Old Jan 28, 2013 | 07:47 PM
  #133
Mrmerlin's Avatar
Mrmerlin
Team Owner
you can install a new modulator with the trans in the car
Old Jan 28, 2013 | 07:51 PM
  #134
Dean_Fuller
Yep...I made sure before I continued my assembly. Thanks goodness as I do not want to do that again soon.
Old Jan 28, 2013 | 07:55 PM
  #135
Dean_Fuller
Any idea why I needed to adjust the pressure after a new pump seal??? Is that normal? I don't know what I could have done to get the pressure off so much. Other that testing for a vac leak...thats all I did to the modulator.
