bending front bumper
my front bumper (the silver aluminum one) has been bent by the previous owner. I am hoping I can bend it back into place. I tried hitting it with a small sledge... no luck That was on the car though.
does anyone know how to get it back to shape? here are 2 pics of it:
its aluminum I believe. I am thinking that maybe if I take it off I can hammer it back straight. Or maybe take it to a machine shop. I can get a used one for 100 bucks, but I was thinking if I could save that cash, even better.
I am pretty positive it is aluminum. I was told that alum is very difficult to bend. I assume that to be true since it didnt even budge when I hit it with mini sledge.
does anyone know how different the 87 front bumper pieces are compared to the 80-82? they look very similar and I can get one of those for about 70 bucks in good shape. I am trying to put the 80 back together so i can sell it after I use what I need from it for my euro.
I know there are differences between the s4 and 1980 front end as far as lights (I think), but will I be able to use that bumper piece? I am fine with doing a few minor mods if I have to.
You will have to remove the lights from bar, and probably remove aluminum bar from car. You can definitely bend it back. You might try cutting a wooden block to go in the channel of the bumper and squeeze the whole thing in a vise. As you get it closer, you may use a hammer. It does not need to be perfect.
Good luck,
Dave
Good luck,
Dave
thanks guys. I am definitely going to remove it first and take all the lights off. I have done a little research since this post. What I have read seems to suggest that thick aluminum like that isnt very easy to bend back. I am hoping that is not the case. I have a plumbers torch and if i have to heat it a little I will. I may end up taking it to a machine shop. I really dont want to spend 100 bucks or so on a used one.
I like the crescent wrench idea for leverage. Heat will also help. It is very easy to remove that bar, I think two allen head bolts.
Good luck,
Dave
Good luck,
Dave
the wood inner block is a good idea. Use two to leave room for a humungous wrench in the middle.
Cheater bar on the wrench.
If it's aluminum (ignorant here as I haven't played with my bumper yet) -no heat on aluminum.
