How to use the Other Gear Options for an Automatic.
#48
For shifts down to 2 at medium speeds (that can seem a bit harsh if there's a biggish rev difference) I find it helps if you give it a bit of throttle as you move the shifter - you get a smoother kickdown-type downshift rather than an engine brake/under-rotation type of shift, if that makes sense!
Presume it's helping to rev-match a bit better and is sympathetic, not harmful to, the transmission?
