Headlights
Headlights
Hey guys,
87 S4 driver's side headlight is not connected to bracket underneath. I can pull it up by hand and it doesn't rest all the way down like the PS. Is there a write-up on how to fix this?
Team Owner
If a gentle push wont set the lamp,
you might want to take a look inside the fender,
the light may be hitting one of the horns.
Electron Wrangler
Not a huge amount - there is a friction cam/clip - pops in & out - test the other side - you can pull it up and then click it back in - that side is obviously OK. If this one is much harder may be worth a look at the mechanism in comparison side to side - see if anything is binding up.
Did you change anything recently there?
If you really need a good look you can take off the wheel and fender liner - but you shouldn't need to... Just remove the cover (3 screws) and the headlamp (4 screws) - you can see a lot more...
Alan
Alan
Electron Wrangler
