Power mirrors and drivers seat innoperable. Where to start?
Team Owner
as posted earlier one of the upper seat rail bolts may have come loose , if so its jamming the rail,
get a helper to lift the seat while you work the motor or turn the front cable drive.
Make sure to check these bolts after you get the seat out.
Consider using a sharp chisel on the side of the bolt head to get it moving
While trying to move the seat back and forth. I am back to no power. Giggling the wires no longer working. Cable drive is about shot-Thanks PO. Guess I'm F#$%^$ now.
Thanks.
Thanks.
Found this thread posted by aircooler but don't know if I dare try it...-
I managed to find an easy fix. I pulled the metal retaining clips that held the ends of the seat drive cables to the emasculated fore/aft motor (It’s the one in the front and easy to access), and attached 2 cordless drills to each cable end. Then I simply ran both drills in the same direction to easily move the seat fore and aft to access the seat mounting bolts to remove the seat. No sweat!
Those little white drive cogs for the power seats can be purchased separately at the dealer. They are under $2 each and are very easy to replace. That was a pleasant surprise as I thought I might have to get them with a new motor ($).
Total repair cost....$6
Hope you are enjoying the summer,
Mike
Mike
