ARRGGGH! Failed emissions again...
#31
Supposing your damper has bad vacuum, can this affect the vacuum force available for the heater valve? In other words, is heat leaking into the HVAC possibly due to these fuel line vacuum issues?
-Sean
-Sean
#32
I've seen quite a few failed FPR/Dampeners, not all that unusual. I test them each time I do fuel hoses or top end refreshes.
#34
At risk of wandering off topic, but my car quite often has really "hot" hot starts. Meaning, it sometimes catches before the first crank is even completed, which sort of throws the start sequence out of whack and the fuel pump hasn't even started working yet; usually I just have to start it a second time. Is this a symptom of some fueling issues? It's like there is flooding in the line that doesn't belong in there. This is a fairly recent development, but the car runs better than ever generally.
-Sean
-Sean
#35
-Sean
-Sean
Cheers,
#38
WOOT! BIG SHOUT OUT TO SEAN! Went to his recommended guy, tested via tail pipe but without putting on rollers and passed with FLYING COLORS! AND Sean then tested my FPR and dampener and all in excellent condition!
Just one more year to do emissions test then no more!
THANKS SEAN!!! Owe you a beer or twelve at 3rd coast!
#39
So then if I had a leaky injector, wouldn't I have trouble starting the car after a while, because of low pressure?
Congrats to OP concerning smog, I know it is a nail biter for me here in CA. I passed by 1 ppm in both of my recent test in the past 2 years.
-Sean
-Sean
#40
Depends on the rate of leak. Too much could flood one cylinder until it is cleared with the other running cylinders. Any loss of pressure is only a problem when the under hood temps are high, allowing vapourisation of the fuel. The resulting vapour lock can make the car very hard to start as the fuel pump can't move it. So you then have to wait for everything to cool down.
#41
#42
#43
From what he told me it is the operators decision with a major factor on using the rollers or not being safety. He said he is not comfortable due to inadequate tie down points in putting some cars, the 928 being one, on the rollers. He just puts the probe in the tailpipe, and runs the tests that way. He said as well the lack of load on the wheels makes much easier to pass...
