View Poll Results: Borla or Magnaflow
Voters: 24. You may not vote on this poll
Borla of Magnaflow?
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I looking to replace the warn out Pumpkin on the 85, not as easy as the S4 type exhaust on the 86.5
Archive Gatekeeper
S4ordie , do you have a X pipe ? any drone? any dyno results ?
https://rennlist.com/forums/928-foru...tallic-s4.html
Dyno results on a stock GTS (post #15):
https://rennlist.com/forums/928-foru...sentation.html
pics were during fabrication - this is not the current on-road stage.
I installed a set of magnaflow and am very happy with the sound. since the magnaflow are straight through it creates an open throat'ed sound - from a growl to a howl.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
my 84 auto is my preferred DD, so did not want too loud.
solution? headers into a 2.5" x 2-input and single 3" out where the CAT would go.![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
added a magaflow 3" in/out X 5" round (not shown) where the pumpkin would go to bring down to a nice sound. not loud and only a minor drone with both mufflers in place.
can easily remove the end muffler and install an extension for an even louder and better howl / sound.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Magnaflows!!!!! Went from Pumkin (no power, no sound), to RMB (too loud), to big a$$ coffee can (still too loud), to magnaflow (just right). Smooth, no drone............sounds great with throttle!
I'd like to say Borla. But from past experience- Magnaflow. I like the sound of flowmaster 40s but can't abide by the restriction caused by the directional veins.
Running one high flow muffler on either side will be loud, I have two resonators ahead of the primary muffler. Revers can work too- primary mufflers left/right and resonator at the end. Cat presence/absence/configuration also weighs heavily on sound/noise.
Fitment can be done- shown is a medium case Magnaflow with internal x.
Snizinskas (09-30-2023)
Both.
I actually have both.
The Borlas are currently on, one on each side:
Video with sound
![](https://lh5.googleusercontent.com/-hAAV3LpeDqI/TJULS6PUikI/AAAAAAAABo0/tryhXYmp96A/s800/IMG_1282.JPG)
The Magnaflows will become the alternative, quiet exhaust with a oval cross-over tube and an additional 4" rear muffler that will combine the pulses the second time after an unequal flow path:
![](https://lh3.googleusercontent.com/-dh-QuxrOTlQ/TOfzn_08NvI/AAAAAAAABzA/6MOAOqqUqIs/s800/IMG_1723.JPG)
Neither brand will restrict power when the right muffler is chosen. Neither brand will on it's own produce a nice or quiet exhaust note. It's the complete exhaust layout that matters, the location of cross-overs, the length of sections between mufflers, etc. Any seemingly trivial choice in fabricating the exhaust is going to make a bigger difference to the sound than the choice between these two muffler brands.
So choose based on price and what fits the best for your optimal space?
Video with sound
