dose this happen to you in your 928?
#31
Hence the quick & dirty posting, lots of words, no meat.
My own kid does this, but she's in 9th grade..
#32
Mine doesn't and refuses to as all her friends do it and it disrupts the class. She's too busy taking pre-college classes and doesn't want the distraction.
#33
Rennlist Site Sponsor
Ricky:
The fluid level in the automatic transmission is critical. To check the fluid level:
- The car must be level front-to-rear and side-to-side.
- The engine must be running, and the transmission must be in neutral or Park.
- The fluid level must always be between the two upper marks on the fluid tank when checked.
- Be very careful to avoid dropping dirt into the tank or fluid.
#36
Should the car be warm or cold while running and in neutral ? I have seen some say take it around the block, others say get it hot and some have said start it up and check cold.
#39
#40
So we should assume you are busy draining and refilling the differential before further transmission investigation?
