89 S4 passanger door pin for lights door jam
I have been fixing all the things the painters guys hosed on my car since I have it running and this is one I could use a little help.
When the removed the pass door pin, the broke it and the wire is in the jam somewhere.
Is there an easy way to get to the backside of the jam to push it back through?
I did a quick look around the jam, pulled the inner fender well and next thoughts are pull the glove box...
Am I missing something or is this the PITA it seems?
Thanks...
If I could just put my time in the things that needed work before I took it to paint this puppy would be mint by now...
Thanks...
Answer is.... Its a Real Pain in the A$$$$... or almost a cannto do, but I got lucky... had the alarm put in the car today and we went with a new wire and got everything working like factory... so solution is $40 and let the alarm guy do it... no access where the wire fell!
Team Owner
if you take a piece of mechanics wire and a flash light you can hook the brown/white wire inside the door frame put a sharp bend in the wire so it will catch the brown wire,
yes you would go through the pin switch hole
yeah, that is what I was going to do, but the alarm guy reran a wire and had it all working before I had a chance to talk to him... so I went with that... if I am feeling real motivated one day, I might do it for kicks...
