Dash "D" light went out - how hard is it to fix this?
#31
Jetrainor,
All can be fixed. Given nothing works(electrically), you can order a new printed circuit foil from Roger(928srus)
https://928srus.com/products/928-641...l&_ss=e&_v=1.0
Lots of info online on how to replace it. You may find with new contacts, things will work. I found my gas gauge worked much better after cleaning the contacts.
The broken odometer gear isn't too bad either to do.
#32
Reverse Switch
If anyone has need of the broken lock switch, I would ship it to you for $50, it was NIB from by Porsche 11/2011. You might be able to cannabilize a lock ring from someone else, worth a try in view of what a new one costs. YMMV.
#35
im fitting one of those foil circuit boards tomorrow, may post the process. already fitted a replacement rear casing and replaced the 3 cable quick connects. still have a flickering right hand battery and oil pressure as connector to foil connection must be dodgy.
