PSD slave cylinder options
#76
Next, I needed something to align the wide part of the socket and the piston, so I could push the expanded ring from one to the other. I used a piece of 3/8" rod. Again, it was pretty close to what I needed and kept the alignment I needed.
#77
When placing the seal onto the socket make sure the ring is oriented as shown. The smaller step in the same direction as the smaller part of the socket
#78
Now I stood the whole assembly up on the table and applied heat with a heat gun. Be very careful, as a little heat is all that is required to allow the seal to stretch onto the larger end of the socket. A hair blower would've been a better choice, turning the socket to distribute the heat evenly. Once warm, I used the conduit to push the seal onto the larger part of the socket. The seal stopped right on the edge of the larger part of the socket. I couldn't photograph the pushing because I needed one hand to hold the heat gun and the other to push the conduit. I wore gloves because the socket got hot.
#81
Wonderful write-up, pictures, and search for the correct seals. All of us with PSD units are indebted to you for this great solution to a leaking slave cylinder - whether it leaks now, or when it does in the future.
Do you have any more seals for sale? I didn't see a response to my request back on 1/31.
Thanks again for a great job.
Gary Knox
Gary Knox
#85
Basic Sponsor
For those that are interested I stock these seal kits.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
