RPM on EZK has noise but LH looks clean via Sharktuner ST2, hall sensor faults
ST2 works great now that the hall sensor and the RPM sensor have been replaced. No more glitches in the data.
Getting the RPM sensor out was not too bad... the connector under the maf.... what a pain in the ^%%$. Removing the maf is required. Still really difficult getting your hands on that connector. The RPM sensor connector crumbled just like the hall sensor.
The hall sensor was not too bad getting back in... I repaired the wire running under the AC compressor. It was cracked and had exposed wire.. shielding on all wires was exposed at the bend point. Sliced open the casing and re-insulated each one. This seems like the only thing I did that would make the connection to the EZK suddenly start working. I did not think this would do much but its working perfect now.
The tape measure picture is a hall sensor with the correct length wires. Most of the hall sensors you find out there will claim they fit the 928 but the wire will be short. A short wire will make it difficult to use the connector mount on the hall sensor cover. Get the correct sensor..... I was told Roger stocks hall sensors with the correct length wire.
