Lizard Shifter Installation Tips?
#46
Drilling instructions here:
http://s287999742.e-shop.info/online...er+install.pdf
But really, you use the new crosspiece as a guide:
"Position the bar so that the center of the pivot point is in line vertically with the lower shift rods pin. This isn’t 100% critical and can be adjusted at the back a little. Also have the positioning so that the raised ring of foam in the tunnel opening should just fit between the shifter bar and tunnel."
#48
You may be over thinking it. Center it fore/aft in the tunnel hole. You can't go too far fore or aft or you run out of bolt/hole space. The make it about 1/3" from the passenger side and parallel. Use a hammer and the bolts he provide to make the spots and drill the holes. I think you don't need micrometer precision here, as you will be adjusting the connection at the shift coupler anyhow.
#49
Trying again using the Photobucket Ploy:
Here is how I got the end of the front shift rod loose/off. Obviously this picture is after the fact, but shows the vice grips and the flare wrench in place ( and the ragged ball cup)
![](http://i1313.photobucket.com/albums/t542/KenRudd/Short%20Shifter%20and%20Rear%20Coupling/IMG_20130416_195436_zps43cea496.jpg)
#51
Shift Coupler almost off. For some reason, it got hung up at the very end and required some hammer induced persuasion to come all the way off. Some type of burr or grit I suppose.
![](http://i1313.photobucket.com/albums/t542/KenRudd/Short%20Shifter%20and%20Rear%20Coupling/IMG_20130413_181924_zps5130b87d.jpg)
#56
If that is the case than only the distance from hole to hole is the important dimension to take into account when drilling. If this dimension is given (mm) together with an approximation of the gap between bracket and side of the tunnel opening (from xx mm to yy mm) than the car can be prepared for lizard shifter installation later on.
