Need switched hot wire feed
Anyone know an easy source for a hot feed wire with the ign switch in the 'on' or run position? I need it to feed my vacuum pump so it has to be a reasonably larger gauge. Not much vacuum at idle with my cams.
TIA, Hammer
TIA, Hammer
How much vacuum are you making?
I would recommend taking it off the fuel injectors. They are switched in the engine bay. You can use it to trigger a relay in the engine bay to run the pump off the jump post.
