928 Forum 1978-1995
Sponsored by: 928 Specialists
Lug Nut thread size and pitch?
Old 08-10-2012, 01:45 PM
Dean_Fuller
Dean_Fuller's Avatar
Default Lug Nut thread size and pitch?
Does anyone know the Lug not thread size and pitch. I am looking for nicer nuts for Marvin.
I found in Green ( forged aluminum ) that are 14 X 1.5 and not sure if that works.
http://www.ebay.com/itm/20PC-2010-CH...020888&vxp=mtr
Thought they would look nice with the silver twists without getting too ricey.
Old 08-10-2012, 02:07 PM
Glen McCartney
Glen McCartney's Avatar
Dean, not sure offhand about the thread and pitch, but taper seat on those will not match up to any Porsche wheels, maybe aftermarket wheels.
Old 08-10-2012, 02:26 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,612 Likes on 1,260 Posts
Size and pitch is indeed M14 x 1.5.
Old 08-10-2012, 03:58 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,315 Likes on 1,289 Posts
Dean those are not the correct seats for the porsche wheels,
The ones you have posted are bevel,
YOU NEED BALL SEAT LUGS.
WARNING if you use the bevel lugs they will seat at the inner area of the wheel bolt face and deform the area,
thus peening the inner area into the studs and then you may not be able to remove the wheel.
I had a car here with these bevel lugs on it with brand new Porsche wheels,
the actual contact on the seat area was about 1/2 a mm and the wheels came off with small pieces of the seats being cut off by the threads of the studs.
I wouldnt release the car till the proper lugs were installed
Old 08-10-2012, 04:04 PM
77tony
77tony's Avatar
Dean, www.autoatlanta.com P/N: R99918200101S has really nice polished alloy lug nuts, set of 20 for $ 120.40 shipped to your door. These are the stock style and will work with your wheels. Just put a set on the GTS and they look great. T
Old 08-10-2012, 05:03 PM
brutus
brutus's Avatar
You can simply polish the stock nuts.
Old 08-10-2012, 08:07 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Dean wants his nutz to be GREEN
Old 08-10-2012, 08:23 PM
GlenL
GlenL's Avatar
Makes perfect sense.
Old 08-10-2012, 09:22 PM
jpitman2
jpitman2's Avatar
VW nuts fit and have the right rounded faces - I carry set for when I need to use the spare..
jp 83 Euro S AT 54k
Old 08-11-2012, 12:57 AM
Dean_Fuller
Better than BLUE.......someone was going there sooner or later.
Old 08-11-2012, 11:17 AM
GlenL
GlenL's Avatar
Can you get green anodizing on aluminum? Have black ones stripped and coat those.
Old 08-11-2012, 11:30 AM
Dean_Fuller
I don't know....I was thinking powder-coat as well but don't know how it would hold up. I have tried painting but that does not survive past the second or so wheel removal.
I may research more on that.
Old 08-11-2012, 01:11 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
You can do home anodizing in any color...
Quick Reply: Lug Nut thread size and pitch?
