stop lamp warning light problem
Hi guys , new problem since couple days , the. Stop lamp warning light on my dash. Has been on at all time when driving , only goes off web the brake pedal was pressed. I Checked all bulbs and I found one of the reverse lights was burned so I put new one and " stop lamp" warning light is still on, what does that mean ? Switch ? Check out the video
http://www.youtube.com/watch?v=_HJlApfU0GE
This might be helpful
"Make sure you replace all light bulbs in pairs, different bulbs can trigger the warning
system"
http://www.928oc.org/tip/tip006.htm
'80 911SC Targa (owned 5 days)
'89 S4 GP White/Black
'76 912E Silver/Black
system"
This is absolutely correct. Replace both stop lamp bulbs with same brand and type bulbs to see if that cures the problem. Also, IIRC, replace the bulbs with small globe bulbs to keep the melting heat away from the lens.
