Custom Retaining Clip
I was talking to the owner of a machine shop that has done some really nice work for me - not the same shop that did those pins. We were discussing the oil check valve in the heads since I asked him to replace them as one had a scratch on the seat where the ball sits. I explained what is recommended to do to secure the seat in place, but he's not a fan of "glue" / staking. After some discussion he suggested machining a small groove just above the top of the check valve to place a retaining clip - this should address any possible movement of the valve seat ever again. Right now it's a thought, and he's not even looked to see what's available in parts.
So, I wanted to toss the idea out to the 928 forum to get your thoughts on whether you think this would work, or even if it's been tried before. Any thoughts or feedback would be great.
Thanks,
Dave
Thanks,
Dave
Concerns are how the retaining ring will sit when the heads / block reach their running temperature - I'm worried the spring will catch on the retaining ring and either become stuck, damaged, or break. I no longer have the heads at home (they're at the shop), so I can't measure or play around with them to get a sense of how it would operate. Does anyone have a high resolution photo of the oil check valve with the oil channels visible?
Thanks,
Dave
Team Owner
it would be possible to cut a groove into the area above the seat then a round body snap ring get fitted then the ball then the spring I dont see how that spring will touch the snap ring as the ball will be between the seat and spring,
The snap ring will sit just above the edge of the seat so its a low profile fitment.
It would still be a good idea to use green locktite when fitting the seat.
The WSM has pictures and describes how to fit the seat
