Need help and advice on getting AC going this weekend
Chronic Tool Dropper
The original oil in the compressor is mineral oil (not the medical stuff). Get that out before you try to add a different oil to the system. Pull the compressor out completely so you can replace the manifold plate o-rings, and while it's out you can drainthe oil oil and flush with new a few times. The add the proper amount of new oil for the whole system. You must change all the o-rings in the system if yuo use polyolester oil. ALL of the o-rings. With the new oil in the compressor, turn the compressor by hand in the installed system, maybe 50 rotations, so that there's no chance that you have filled a cylinder with liquid. Put the belt on, install the drier, seal everything up, and pull a good vacuum on it overnight. Check the next day that vacuum is deep enough that all moisture is boiled out, verify that there are no serious leaks by stopping the pump and watching the torr gauge. Then charge with liquid by weight. Let the car sit for a few minutes to make sure there is no liquid left, sniff with a leak detector. If all is OK, start the car and verify function.
There is a actually a good chance I did change those out already so I might be doing it twice. It has been a while but I have it in my mind that the lines going into the compressor were all resealed. So maybe I did drop the compressor if that is what needed to be done. I would assume if it holds a good vaccum it should work when charged if all the electronics are in order. The oil I have is call Esther 100 from Napa. It says it is a synthetic that is compatable with R12 and R134. Do I need to drain all oil or do you think this will work.
Its not too hard TO drop it, belt comes off easy, two bolts hold it up at the top..one in front, one in rear. And four allen bolts hold on the plate with the lines.
Four HUGE Orings are under that.
If they are original, sure it could work fine, but..you may end up back in there in a few weeks of re-use.
I dont have the answer on the oil.
I dont recall the size of the Orings under the plate, maybe..19mm? All 4 are the same size.
You're in Nebraska....
Your'e in Nebraska, Not sure where, but in farm country, there are any number of independent mobile guys that repair and maintain farm equiment...including the A/C units in the combines and harvesters...most will have a decent vacuum pump...may be closer than you think..
Found some, but don't know stock levels. It is still available at most AC parts houses.
http://www.summitracing.com/parts/FSS-59000/
I talked to a local service tech and he did say that they use the Poly Ester when they convert to 134. He basically said the same thing as the bottle says. The new formula is compatable with the original oil. According to him when 134 first came out they made them drain all the oil completely when converting but now they tell him that is no longer needed with the new stuff. The next thing is a vaccum. Has anyone ever made one? I called the local auto places and none of them had any for rent. I really do not want to take the car to a shop if I can figure out someway to vaccum at home.
There isn't any way I know of to create the deep level of vacuum necessary short of a deep draw vacuum pump. There is a device that uses compressed air to create the necessary level of vacuum but few folks will have access to a compressor that will supply the required volume and pressure for the amount of time required to generate the level of vacuum needed. If you are anywhere near Lincoln or Omaha you can pick up a fair vacuum pump at Harbor Freight for $100, less if you have one of their 20% off coupons.
Mike
Mike
Mike
Mike
