928 Forum 1978-1995
Sponsored by: 928 Specialists
smog pump- how stiff to turn? (86.5)
Old 07-27-2012, 03:39 PM
Jim Devine
Jim Devine's Avatar
Default smog pump- how stiff to turn? (86.5)
How stiff should a smog pump be turning the pulley by hand? Mine feels fairly stiff/ tight, but doesn't seem like it's bearings. I'll need it to work to pass
emissions after a non op, so no use finishing reassembly if it's bad. Don't want it to seize.
Old 07-27-2012, 03:53 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
My pump belt has been off since I bought.
Passed 2 smogs...its just in who you see and have a relationship with...and if you do pass clean.
Old 07-27-2012, 04:03 PM
Jim Devine
Jim Devine's Avatar
Angry
My "favorite" smog guy got suspended by the BAR
for closing his eyes to missing/ altered parts etc.
So, may as well have it work.
Old 07-27-2012, 04:15 PM
Speedtoys
Speedtoys's Avatar
Ah..that sucks.
I anticipate...that once the numbers work out for the car population, California will only smog OBD cars.
Every time a Pre-OBD POS falls off the registration list..the closer that day comes.
Old 07-27-2012, 04:20 PM
Leon Speed
Leon Speed's Avatar
I imagine it feels sticky due to the weird design. By rotating the pulley, two vanes move in and out from the center towards the outside of the pump. The vanes are in there tight and slide against a metal spring plate. My description sucks but what I am saying is moderately tight is due to design. I think. If you rotate the pulley, the resistance should be felt at one specific point (twice per full rotation), then it should turn easier again.
Edit: it is easy to take the pump apart and clean and lubricate the bearings (4). Reassembly is a bit of a puzzle, but doable. Don't brake the carbon sealing plate between the pump housing and back plate.
Quick Reply: smog pump- how stiff to turn? (86.5)
