'84 Euro S2 fuel pressure increase
Ive got my 84 euro running with an adjustable FPR around 50psi, stock fuel dampener and s3 dampener. Like my results with the increased pressure, stock pressure was around 30psi and it ran too lean.
Hi, thanks for replying.
So I take it you replaced the right rear FPR with adjustable and the left rear reg with the s3 damper. Did you need to navigate around having a hose barb fitting. I also assume the the S3 damper accounts for the higher pressure. How did you know it was lean? AFR readings or on dyno. Also is that with stock injectors?
Greg
Greg
Greg
Greg
Does the route through the damper matter. What I am thinking if a three port damper was placed in the rear the inlet would be through the side ports and outlet to the cooler through the bottom. I assume not as they are all connected from what I have seen. It sort of feels like the easiest way to plumb it however I do fear an imbalance across the fuel rails. Then I can run one reg either hard set or adjustable. I sort of want to get this correct as I do run an ECU and need the flexibility for down track.
