Intermittent, but frequent, jumpy tach past 5K or so
Anyone else seen this on a digital dash. Often, when the tach gets past 5K or so, the needle will start jumping wildly - like +/- 500RPM. Sometimes it will stay smooth through 5K and up, but most of the time it will start jumping. Below 5K is always reads well, with no jumping at all. I don't notice anything odd from the engine itself in this range; it revs smoothly right through the area where the tach wigs out.
The car has a Sharktune it, BTW, but I spoke with Jim, and he didn't see that that would have any effect on the tach if it's not affecting the ignition itself.
I'm thinking I'll probably need to feed a sample signal into the tach from a function generator, and/or scope out the EZK feed to the tach, to see whether it's a bad signal or a bad tach, but I just thought I'd ask in case this was an issue someone else had seen (and preferably solved) in the past.
Thanks,
Paul
Thanks,
Paul
Archive Gatekeeper
No idea what you're talking about. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Sometimes I get a jumpy tach in the immediate moment after the key is turned to the start position, I always assumed it was some sort of voltage spike-y event as the car comes to life. But the tach needle is steady whenever she's running.
Now my temp gauge, that's a different story:
My gauge are all steady (stock ignintion) I assume that your pod was out when you replaced dash (and did the same problem occur prior to this project) are all the connector locked-on and dash related grounds OK?
