cleaned motor- now does not run!
the basic problem remains- I washed the engine on wednesday and today is Saturday. The car starts fine-idles about 20 seconds, then it dies. It has been sitting in my driveway and I am using another vehicle because I knew it was not running well from the startup when I first started the car on Thursday to go to work. So I have been using another vehicle ever since. I will move it to an air conditioned garage tonight to dry things out.
In the interim, I would check all your fuses and make sure the area around (and behind) the (CE) Central Electric panel is dry.
The engine bay gets soaked everytime you drive in the rain.......
I actually pressure wash a good deal of my engine bay. But this is after doing a full top end refresh.
Never an issue.
Never an issue.
How?? Like almost every other street legal car ever made, the 928 uses weatherstripping to reduce that... the only way water should be able to get in is if the seals are bad/missing, or through the gap between the hood and fender.
I've had success in drying out engine bays by putting a small electric fan heater, under the car, pointing under the engine compartment with the hood shut. If you position the heater so that the air rises under the motor it will warm up the whole engine bay and dry things naturally, without having to use compressed air which can sometimes blow water even deeper into a loom, plug or electronic enclosure. I've used compressed air after that to get rid of any remaining moisture, and then warmed everything again.
I'm with Colin on this as I built a new harness when I installed the tec 2 and be dam'd if ILL go to a car show with a dirty engine.
That said, after a wash you have to blow some connectors out
1) Hosing down engine is not a certainty of problems..but based on the pre WW2 connector plugs our cars use, age + water can be bad at some point.
2) WO pans, it wont soak, just get more road crap up there, a little..but not a big deal, IMHO.
From the symptoms described I would suspect fuel rather than spark.
I would start with MAF, Temp, TPS, etc. Everything that affects fuel, especially at idle.
But checking the caps and wires is easy enough so it can’t hurt. Unless something breaks in the process.
When you drive on a road air and water (when raining), go through the radiator and get carried all over the engine bay.
I'd like to see you stop that!
