928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine oil - what are you using?
Old 07-05-2012, 01:38 PM
s4bill
s4bill's Avatar
Default Engine oil - what are you using?
"For a 928 a synthetic 5w-40 “mixed fleet” Heavy Duty Engine Oil (HDEO) is probably the best choice of all and far exceeds the A3/B3 or A3/B4 ratings"
Is this what you are using?
Old 07-05-2012, 01:47 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
For a year I had Shell Rotella 15W-40 in my GT, per one of Doug Hillary's oil threads. It did not like it when stuck in traffic, at 90+ degrees, triggered the oil pressure warning (albeit on a '90, with no oil cooler in the radiator..) How hot is it in Maryland today?
Old 07-05-2012, 01:53 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Royal Purple 10/40. Expensive, but so far zero problems.
Old 07-05-2012, 02:00 PM
s4bill
s4bill's Avatar
It is 100 in the city. It is predicted to reach 108 on Saturday.
My AC is not working in the car. That is a separate thread.
Old 07-05-2012, 02:04 PM
Rob Edwards
Archive Gatekeeper
FWIW, in a driving season that ranges from 50 to 105oF, I like Torco TR-1 20W-50.
Old 07-05-2012, 02:08 PM
UKKid35
UKKid35's Avatar
Penrite HPR15 - no more oil pressure issues even on hot trackdays. Car is usually laid up in the winter.
Old 07-05-2012, 02:11 PM
s4bill
s4bill's Avatar
That is the reason I ask. I thought for sure someone (or maybe even a consesus) on one of these forums suggested that I use 20w 50 Mobile 1 synthetic.
I am going to change the oil shortly and want to do what is best.
Old 07-05-2012, 02:18 PM
Ducman82
Ducman82's Avatar
Castrol 20w50 here. till this motor is broken in then Mobile or Redline.... what ever is local.
Old 07-05-2012, 02:42 PM
deutschmick
deutschmick's Avatar
Mobil 1 15W-50. It's not tracked, but has seen some 110+ days in Phoenix stop-n-go traffic. No oil pressure problems so far. I wish I had an oil temp. gauge though.
Old 07-05-2012, 02:45 PM
mickster
mickster's Avatar
Ditto. About $25/5 quarts at Wally-mart. On Special now at $6/quart at NAPA (no bargain).
Old 07-05-2012, 02:46 PM
auzivision
auzivision's Avatar
M1 15/50 once a year (less than 10K miles... maybe less than 5K lately).
Thanks for the reminder, I'm due now
Old 07-05-2012, 02:48 PM
Bilal928S4
Bilal928S4's Avatar
I have always used Castrol 20W50. When I did my oil pan gasket and had a peek inside it was very clean. The car had 118K and is the 90S4.
Old 07-05-2012, 02:51 PM
s4bill
s4bill's Avatar
Now that it is mentioned several times. I think it was 15w 50. This is the reason why I ask.
Everyone loves Wally world.
What are the pros and cons of using 15w 50 vs 20w 50?
Old 07-05-2012, 03:11 PM
redpathtribe
redpathtribe's Avatar
Another vote for Mobil 1 15-50. Have been using it for 12 years, including track days and auto-x, never had any issues. That's in Phoenix, so it does get a little warm here...
I think most dino oils are 20W/50 and synthetics are 15W/50. I'm sure most dino oils in that weight would be fine for normal street use, you'd just have to change it more often. I use a synthetic because of the high heat in Phoenix and my 928 is a daily driver.
Old 07-05-2012, 03:33 PM
jetrainor
jetrainor's Avatar
Use 15-50 Royal Purple.....some of my hot-rod buddies claim i'm losing 'big' HP with the 50 end of it...
Quick Reply: Engine oil - what are you using?
