Anyone know what this is?
There is a vacuum manifold there that splits vacuum for the HVAC system, transmission modulator, rear damper, and FPR, IIRC, but I didn't think that was yellow/white. From what I remember it's black and rubbery. Maybe someone replaced it at some point?
OB's dont have the 6 way that i think you are talking about. there are usually 3-5 nipples for vacuum directly on the intake/throttle body. ive never seen that piece before in that location on mine. Only thing that comes to mind is that if yours is a 5-speed it might be clutch related. otherwise you should have a bolt on the front of the spider holding a metalic vacuum tube for the AT. Now ive gotta look when i get home to be sure!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
My car is an 84 US AT.
If you do look check yours, look off the brake booster I have 1 of those 4 connector thingies.. and only 3 of them are connected. I'm trying to find out where the 4th connect goes..
