928 Forum 1978-1995
Sponsored by: 928 Specialists
LH spider Injector Conversion.......
Old Jun 27, 2012 | 06:21 PM
IcemanG17's Avatar
IcemanG17
Stock is 24lb..............at 39ish psi.......runs just fine on all L and LH jet 928's
My duty cycle at idle is around 5%
Old Jun 27, 2012 | 07:40 PM
123quattro's Avatar
123quattro
Originally Posted by Ducman82
thats what i figured. 26's are what ill use. 36's will make it run a tad rich.
I thought you were going to a stand alone controller? If so, it doesn't matter what size the injectors are as you'll be remapping the entire engine.
Old Jun 27, 2012 | 07:45 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
ya I'm doing Mega squirt 3 with sequential. injectors are a cheap enough change out if i need more when the time comes.
Old May 1, 2023 | 04:37 PM
Aluminumme's Avatar
Aluminumme
Default Holes
Originally Posted by 123quattro
I drilled the injector holes in the runners to take a standard injector. It took about 10 minutes.
what was the hole size to drill out the threads on the spider down pipes
