Relay Test Rig
Rennlist Site Sponsor
Apparently, I misled many folks with the title - the idea was NOT to test a relay, but to test the circuits in which the relay is installed, especially when there may be an intermittent fault in one of the circuits. Testing relays is pretty easy...
I too contemplated something along these lines for diagnosis, but as a novice I wasn't sure how often I would need it. When looking into the Lisle Test Kit I found a short video showing the simple probing and jumpering of the circuit.
I really like Wally's idea with indicator LEDs so show the state of the circuit without having to probe with a multimeter or testlight. Easily accessed 'live' information is always good!
Perhaps integrating functionality, like that of the PowerProbe, to drive the LED indicators (and as an option - speaker output indicating either the closed or open state) would be beneficial?
-Mike
-Mike
Electron Wrangler
I designed something like this a long time ago.. feel free to use the schematic - the nice thing is that for most cases you need no additional connections since can automatically finds its own power & ground on any pins... You could of course also connect A to battery power and B to ground if desired... and I would recommend connecting the ground to B for best results.
I did build it - not sure where it is now, It worked OK but was rather awkward to wire up & maintain good relay operation. See the picture of the opened relay - the wire goes through a tiny grommet on the can top above the pin below the coil - its very difficult to avoid the pigtails interfering with the mechanism as you push the can back on - even then the wires can still pull-off even after closing it back up.. a real PITA!
In the end it only helps with 53 style relays - and mostly these are easier to debug just by replacing them, I just didn't use it much.
Sorry don't have a better picture of it - the LED's were Red for Power (High) & Green for Ground (Low).
I did also make up several cans with just switches - the one shown part way built here here is very low power SPDT but I did do one with a pretty decent SPST switch in it...
I never did build a true break out box - but I planned that also - so you can more easily get a voltmeter on all the relay pins when operating...
A break out box with monitoring like this on all 9 pins would be really useful for all relays and a double that could also work with the headlight relay and defroster would be really really useful...
Problem is finding female relay sockets with all 9 pins... 5 pins are easy.... More difficult still is finding a relay base with all 9 male pins mounted to use as the plug in unit. I gave up when I couldn't source these...
Alan
Alan
Please don't distract Jerry from the rear wheel liner project. ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
This is two years since I flushed the psd; I'll be running with a plastic bag over the unit the next time I remove that POS. (Sorry Helmut but you know it's true.)
About ten years ago I fitted all my type 53 relays with LEDs across the coils. Sadly the no start was not electrical, it was the cam belt.
A couple of weeks ago they helped me diagnose a failed immobiliser in the middle of our Scottish Highlands Tour, without them I would have been completely in the dark.
![](http://www.928.org.uk/ukkid35/photos/RelayFront.jpg)
