De-oranging my dash
I think I suggested there might be a problem with all the acetone and stuff.
Get some leatherique prep agent. With some maybe 320 wet or dry and the prep agent you should be able to remove and smooth out the bad dye job.
Once the dye is gone use some of the reguvinator oil to bring life back to the leather.. After that you should be able to get the leather to look good. Leatherique dyes are water based and less toxic than most. They also make a filler that works great although takes a bit of patience to apply
Or you could save a lot of labor and buy a cover from Rob
Why not go with vinyl on the dash. It is cheaper and it will wear better in direct sun. Budd's kit is just over $200 or so I think. My sons car has a Budd vinyl cover installed.
The camera flash makes it look a little shiney...it really is not. Blends well really and will not shrink in the sun like leather. If you want the smell them just stuff some fresh leather under the seats.
For reference...the pod is new leather, the center console is OLD leather, dash and glove box is new vinyl.
Just an idea.
Just an idea.
BTW, Dan, I also ordered their filler, which I've used to try to fix the cracks in my pod. I just added one more coat and will sand that when it's dry. It seems to work well, since I prepped it well, but now I have to paint it and am planning on using the color-plus. Any tips for getting a leathery look --like crumpled-up newspaper or plastic bags?
http://superiorrestoration.com/
The company sells an excellent silicon solvent. I use it as a prep before dying vinyl and some times leather.
Dean, did I miss a chapter of Marvin?
Yep...dash recover starts on page 41. Its not bad at all to do. I did it and I am no rocket scientist. I will be happy to help in any way I can. PM me for a phone number if that helps.
