removing throttle linkage bearings
I need to remove the bearings from these 3 linkages. There are 2 bearings per linkage. I can easily use some sockets and a vice to press them out but I'm not sure if there is a seat inbetween the bearings. I dont' want to apply any force until I know they'll both slide out.
Anyone BTDT and knows the safest way to pull these? Thanks.
Ben
Ben
I used the socket/vise method and it worked great. Rob Edwards did a nice picture/write up procedure but I cannot seen to find it. Make sure your shaft is good, I replaced it as well.
Thomas
Thomas
No seats in between on mine. Socket, a vice and some lube did the trick for removal.
http://www.flickr.com/photos/51967142@N00/7335583640/
http://www.flickr.com/photos/51967142@N00/7335584970/
Replaced them using the same method as show in Dwayne's flappy bearing section.
http://www.flickr.com/photos/51967142@N00/7335604466/
What I replaced with
http://www.flickr.com/photos/51967142@N00/7335606010/
We'll see...
Took a bit of digging but I'm optimistic. This outfit only does auto parts for restorations. A few of the other shops I contacted were industial outfits that wouldn't touch the stuff.
You may need to cover the ball section where the rod snap into before you plate. I have the linkage replate the the ***** got bigger
and my linkage rods won't snap back in. Sanding it cause the rod to jump off when ever it feels like (bad feeling when driving). Buying a set of used one made it safe again but not pretty.
