Starting Issue: Need Help
#31
I am going through the same problems you are currently. Did you jumper 3-way at the fuel injection relay outlet, as well as 2-jumper the fuel pump..then try to start it?
I understand the fuel pump is triggered through a signal to the L-jet unit. Ignition switch perhaps not sending the signal through 15 port I believe. The pump may run when testing it but the computer needs that signal to keep it running
Things I were going to check in a couple of days...
#32
The car now starts up everytime and stays on, but runs like utter crap since my AFM is not connected. With the AFM connected, it will not start. I haven't tried running it with jumpers in those two relays, but at this point, I pretty much know it's getting fuel well enough to stay on. I plan on replacing those relays regardless, even though my current ones seem to be working fine.
I'm not sure if our cars signal the same way since I have an LH-Jet vs your L-Jet, but your post has reminded me to replace those relays, and out of curiousity, I will run the car with them jumpered tomorrow to see how it behaves. Thanks!
#33
So your car won't run with the AFM connected, will run with AFM disconnected, and you want to replace relays that you know are good?
*departs discussion*
#34
Yeah mine runs with the AFM disconnected...like crap as well so something in the LH or LJet system is preventing the injectors to fire after the cold start valve. Hence I was thinking faulty relays. My car ran perfect until overnight she decided she doesn't want to start. I don't like guessing and parts changing to no avail. Been hot as heck here..took a couple of days off to re-assess and this weekend I will try again troubleshooting
The hose in the AFM never works for me, and I have a known working replacement AFM unit.
#35
What hose? You're talking about your barn door, right? The black box between your filter box and your intake hole, right?
There is no hose on the AFM. Now I think you may be referring to something else.
#40
#42
#44
I wonder if your AFM's calibration dial on its armature has been tampered with.
#45
I will be full one diagnosing based on Maleficio and Landseer's suggestions..I know it is something simple, and a pain to run from one point to another before you resist and start purchasing parts for a fix,
It has to be a simple fix, based on understanding the Jetronic system (I have been reading and reading)
