mity-vac/mighty-vac questions
are there any post describing how to use a mighty-vac to test vacuum lines?
I tried searching, but I think there are many spelling variations, so I am not finding anything.
I was thinking about buying this one:
http://www.harborfreight.com/mityvac...ump-39522.html
but I was wondering if this would work, and what the difference was.
http://www.harborfreight.com/fuel-pu...ter-93547.html
Why do you pump it?
Do you do it with or without the car running?
Why do you pump it?
Car not running, disconnect at the vacuum source, usually the throttle body, hook up sucker, suck, watch the gauge. If the vacuum never gets very high, its a bad leak. If the vacuum doesn't hold its a small leak. If the actuator the vacuum line is connected to doesn't do what its supposed to, its broken.
Plastic version melted first time I left it in the hatch area parked outside. Not melted to a puddle, but warped and no longer working, and not warrantied.
I bought the cheap metal HF, but haven't needed to use it again.
Get the mity vac in the first pic, it is excellent to test vacuum lines, vacuum actuators, to bleed brakes, etc. The second one is just a gauge, you will need something else to create a vacuum.
Edit: the mity vac looks like it's made of plastic. Better get the one made out of metal.
For testing the vac lines, look here under "HVAC": http://members.rennlist.com/pirtle/svc.html
If you feel the need to have metal, I beat the crap out of one of these for about ten years:
When it finally died, I got the plastic mityvac. I have no issues with the plastic, but have only had it for a year.
Metal with built in gauge. Can use for many things. Combined with the cup you can use as a power-bleed.
It's basically a vacuum source, strong than you can generate by sucking on a vacuum line.
You could test non-ported (idle) vacuum lines simply with a vacuum gauge. A normal reading at idle for a healthy stock engine would be between 20-25 in/Hg for a non-ported vacuum source, if it is lower you may have a vacuum leak, but remember that a simple vacuum gauge can tell you alot about an engine's condition as well (carbon build up, sticking lifter, poor sealing, plugged up catalytic converter causing excessive backpressure). In fact, assuming all vacuum lines/sources are sealed properly, you can use a vacuum gauge to pinpoint almost every engine maladie that is related to the mechanical parts of an engine.
so hypothetically if I wanted to test my auto transmission vacuum line on the center rear of the engine, I would unplug it from the 7 way splitter, plug the line going to the transmission into the mighty vac, pump it up, looking for the gauge to hold a certain amount of vacuum, w/o leaking?
Chronic Tool Dropper
On the device selection-- I had a Genuine Plastic Mity-Vac for years, maybe 20, before it gave out. Body is PVC so there's NO TOLERANCE for anything aromatic. Like gasoline in a leaking fuel damper you might be testing. Replacement is a Sears Craftsman that is amazing identical to the metal Harbor Freight tool, including all the accessories. Of course, the H-F unit costs a lot less, but it doesn't ome with the impressive Craftsman decal on the side of the barrel either. Knowing that, I should have gone for the H-F tool.
You'll also want to cap off certain lines, e.g. if you are testing the solenoid console as shown by Dwayne. I found that #8 screw protectors from Home Depot work well.
BTW, I bought the Harbor Freight (Princess Auto in Canada) metal one. Works very well.
You guys are awesome. I had to buy my MitiVac, have it sit on the shelf taunting my for a few months and then read the instructions to get it to work.
Once I did I fixed my always-hot air misrouted vacuum lines and cruise control issues in a week. Made me feel like an a-number-1 pu$$y.
Shoulda' asked you guys how to make the damn scary thing work
came to $19.99 with 20% off coupon and free screw driver kit-can't get hurt!
