Rear cam cap bolt tool - what is the correct name & size?
I have one similar to Rob's tool there.
But mine is fitted into the 3/8 drive piece with the six sided (like a picquic screw driver), I put a wrench on this 6 sided piece. I then put it in place and slide a big screwdriver between it and the booster holding it in with a fair bit of force. I then can turn it and ensure it wont strip.
Archive Gatekeeper
Rob, how do you remove the lower rear bolt on the drivers side?
I'd do what Colin said- short 8mm XZN drive tool socket with hex flats on it, turned on those flats and held down/in by levering on the end.
Tell you what, after umptiest time finding something can't be reached because there's something else in the way, today I did wish I had pulled the engine. So much easier. Anyway, looks like I need a bit sized zxn. Ebay here I come! Who would have thought Chinese tools would be good for something.
I was thinking about this set http://www.ebay.de/itm/Bitsatz-Torx-...item27c71342f6
but then I found this http://www.ebay.de/itm/GEDORE-Schrau...item3372dc2771
