How to replace those felt strips at the top of the door frame?
Hi folks,
Can anyone share suggestions on how to install new felt strips? The ones that tuck under the headliner at the top of the door frame and run along the frame down to the dash.
The old ones look like they were glued in with something. Not sure whether that was original or something done by a previous owner.
Thanks,
Paul
Thanks,
Paul
Team Owner
you can use the 3M strip caulk on the parts where the strip pushes into the body and trim,
The area where headliner screws are will hold the trim.
You sholdnt need much
