HVAC Vaccum Tank Delete
Looking for some more room. If the Vacuum tank is removed does the HVAC still operate normally? Has anyone tried it?
Chronic Tool Dropper
That reservoir supports the flappy on the intake, the HVAC diverters, and the cruise control servo (right there by the vacuum accumulator). Without the accumulator, the heater valve will open and the airflow will divert to the defrost vents on accelleration. Cruise will work so long as it doesn't ask much of the engine, to the point where intake pressure goes higher than what the cruise actuator needs. Flappy wouldn't work when you accellerate, pretty much the times you would want it to work. Also-- vacuum for tank vent diverter? Need to inspect the vacuum diagram more carefully.
You might decide to find a smaller one and put it someplace else, but I'm pretty sure you want to keep one someplace in the system.
All the HVAC actuators will go to their default positions when there is no vacuum. That's pretty much full hot to the defroster. Center and footwell vents close, fresh-air door closed. defrost vent and heater valve open.
What were you planning to put in that wheelhouse area? Not a whole lot of room there even without the bubble-bottle.
Dr Bob,
Totally agree with your assent as the vacuum tank is the same as an accumulator, in actual fact it is an accumulator at a perfect vacuum (zero pressure).
I have driven cars where the vacuum tank has been too small and under hard acceleration the vacuum actuated solenoid valves would change to default positions.
Excellent posts.
Tails 1990 928S4 Auto
Excellent posts.
Cheers!
Carl
90GT Project
That vacuum pump is interesting. Would that solve my cruise control issue with low vac on my supercharged car. I could take the cruise and HVAC vac circuit completely away from the engine source?? hmmm any comments?
If its the specific space under the fender you need, just move the tank elsewhere. Or use a different style - there are many after market vac tanks around (round ended cylinders in steel), used for things like extra vacuum for trailer brakes etc.
jp 83 Euro S AT 54k
jp 83 Euro S AT 54k
Cheers!
Carl
When I track the car I hold it at WOT for extended periods and never have I felt hot air gush out the vents.
I thought that w/o vacuum, if the heater valve is installed the correct way, the circulation of the coolant will keep the valve shut -> no heat. This would jive with GlenL's experience. Also, the vacuum take-off for the HVAC / Cruise and the bottle is from the brake booster IIRC, so is this affected by the engine / fuel vacuum system at all? I thought they were separate systems. . . . hmmmm. Someone set me straight - I have an 83, maybe it's different than what you're working on.
The takeoff to the one-way valve is from the manifold side of the brake booster check valve. On my S4 that's manifold pressure minus whatever extra the little venturi booster can help. If the hvac is perfectly tight then no need for the accumulator.
Inventor
You could replace the external tank with a 78-79 door lock tank (19), which mounts inside, above the pedal assembly.
![](http://members.rennlist.org/porken/VacDoorLocks.jpg)
Thanks Ken I was thinking the same thing.
Bob I was pondering installing an electric power steering pump in the cavity. Little tight in front of the engine mounting the Pro-Vent, Fuel Cooler Can, and Electric PS.
Tony
Tony
That's what happened to mine. The oil/air separator/catch can sits in the fenderwell instead of vacuum can and cruise control servo. A few spare holes in the fender wall made it easy.
