928 Forum 1978-1995
Sponsored by: 928 Specialists
boost for head gaskets
Old May 14, 2012 | 11:48 PM
Jim R.'s Avatar
Jim R.
Z has it right.
I ran the stock clutch with 8 psi and 255 rear tires. The clutch was fine, just had wheel spin. When I went to sticky 295's, the stock clutch couldn't hold hard shifts into third, forth, or fifth. There are several options out there now, I had a Kevlar clutch with a heavier pressure plate made by Motorsports SLC in Utah, has held up ok so far.
13 psi has been fine, still running the original 1989 head gaskets in mine, been SC'd since late 2004 or so. With the shark tuner being able to tune for fuel and ignition pretty sure mine has less knock counts than a stock car...detonation kills head gaskets, not the boost psi itself. Many times the force in the cylinder with detonation, has to go somewhere.
As for the cars running hot, make sure the radiator is new or in 100% working order and you will be fine.
And other than normal fluid changes, I haven't needed to touch my car in a year and a half. Pretty reliable for a 23 year old modified car!
Jim
Old May 15, 2012 | 12:08 AM
17prospective buyer's Avatar
17prospective buyer
And back we go to the "pull the heads or not" debate... Is there a clear answer out there? Pulling the heads also means disassembly and reassembly of part of the valvetrain.
dprantl's Avatar
dprantl
My GT still has original head gaskets, has been supercharged since it had ~170k miles on it. It now has 243k miles, and over 40k was put on it by me. The car is my daily driver for over 4 years now. It is set up to run 8 - 8.5psi. With proper coolant changes and no detonation, you have nothing to worry about.
Dan
'91 928GT S/C 475hp/460lb.ft
Old May 15, 2012 | 12:23 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I'm as cheap as they come on this board and I would replace the other gasket. My car only came with bent valves on one head but I've replaced both gaskets. This was years before I decided to boost is.
Old May 15, 2012 | 09:58 AM
rgs944's Avatar
rgs944
If you are fine with a daily driver I should be fine for a weekend fun car if it is not abused. I like the idea of using the Murph system in the 6 to 9 range.
Dan
Old May 15, 2012 | 10:03 AM
17prospective buyer
That's why i admire your supercharging system... you saw the approx. 6K price for a 928MS or Murf kit and said, **** that, i can do that myself for a fraction of the price. I plan to do the same thing to my 87 when i start making more money.
Old May 15, 2012 | 07:37 PM
davek9's Avatar
davek9
Pull the Heads off and replace the HG's, check the Valve guides for excessive play, if good just Lap the valves and replace the Valve seals.
Rember like said all those rubber bits are 20 years old and rock hard.
The worst part is the cleaning, and it all needs to go back together the same same way it came apart and very CLEAN
Get at least 32 Zip lock bags (or 16) and bag and mark each Valve assembly so they all go back right where they came from.
Just got done doing my 86.5.
Just do it, then you know what you got,
Dave K
Old May 15, 2012 | 08:39 PM
soupcan's Avatar
soupcan
^^^This^^^
Old May 15, 2012 | 09:15 PM
17prospective buyer
Dave K
Thanks for the advice. I agree very much on labelling and bagging everything by category. When i pulled my engine i bagged and labelled everything by category (what vehicle subsystem it was eg. starter, fuel, intake/induction, exhaust). I wasn't too specific as i can always look at the PET to see which bolts specifically go where.
I think if i pull the heads though i'm going to go the cardboard route, then tape the valvetrain components to the cardboard in the exact same orientation they came out as, and mark the direction of drive on the cardboard.
Old May 16, 2012 | 03:48 PM
davek9's Avatar
davek9
I found the zip lock bags work best for the valves, label each bag by cyl and valve # i.e.:
Cyl #1: I-1
Cyl #1: I-2 (counting valves from front to back)
Cly #1: E-1
Cyl #1: E-2
That’s four bags per cly, containing the valves, springs, spacers, keepers (i also zip tie the spring assembly together so it goes back in the same order top to bottom)
All valves (in bags) for one head fit nicely into a medium size pizza box.
And you get to eat pizza
Old May 16, 2012 | 07:19 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Cyl #1: I-1
Cly #1: E-1
Cyl #1: E-2
This is what I did too and saved me a bunch of headaches.
