Parting a '91 GT
#31
Rear hatch seal?
#35
I would be interested in the shift **** and boot, don't care about the color, just as long as it can be recovered and installed fine. It's the correct "GTS" style I'm assuming? Hard to see on my phone.
Also, I'm in need of the passenger mirror glass. I don't need the housing, but if that's easier and not much more expensive so be it. Lastly, the drivers outside door handle assembly. Mine is on its last legs.
#36
Basic Sponsor
I would be interested in the block to oil cooler hoses and the oil cooler under the rad?
#37
Seriously, I had two sport seats shipped halfway across the country for about $200. They were packed in thick walled boxes lowered over a wooden base to which the seats were mounted. They arrived without a scratch. If packed properly, it can be done safely and relatively inexpensive. Scariest part was picking them up at the bus station.
#38
The visors are black vinyl and are OK I believe. If I can locate the second one, I'll take pictures and post.
#41
Ya..im pretty sure that _tail light_ plugs are sufficiently not self aware, like other relay or component related electronics, to care how much water they had in them for a short time.
Im not asking for anythings that makes decisions, or with moving parts.
12v in, makes light, goes to ground.
#44
Hey Gary,
I need one of the harness connectors (just the plastic part) that connects to the pod as one of my clicps broke and it dose not stay firmly connected.
If you cut 2 or 3 off and throw them in a CD mail pack ILL give ya $20
But I could also use the cluster as well because some of the plastic has worped.
would you be willing to send the cluster and connectors for a price?
maybe the face is less scratched then mine as well. $100 for it all.
Brad
Brad
#45
Hey Gary,
Brad
Brad
Here are two pictures of the cluster (I took them last night without cleaning the cluster up first). It looks to be in reasonable shape except for a spot under the battery gauge where it looks like a small spot has peeled (and the gas gauge needle is off). The connectors and the cluster are yours if you want them.
