928 Forum 1978-1995
Sponsored by: 928 Specialists
help!!!
Old May 13, 2012 | 02:50 PM
kenyawild's Avatar
kenyawild
Default help!!!
New to forum Based in kenya
1980 928S manual Ktronic
Have a spark and checked all the timing etc but not starting. Have noticed that when I turn of the Ignition all is off but am still getting pressure through the injectors and loads of fuel still coming out? And flooding?
Any suggestions ?
marc
Old May 13, 2012 | 02:56 PM
Avar928's Avatar
Avar928
Check your starter? Fuel but no spark?
Old May 13, 2012 | 02:58 PM
911 Crazy's Avatar
911 Crazy
SPAM addict
From: Acadia National Park, Northeast Harbor, Maine
I would start there also and greetings to Africa!
Old May 13, 2012 | 09:52 PM
928 at last's Avatar
928 at last
Sounds like you're off the scale on the rich mixture side. You're going to need to read up on the injection system for the older cars. Lots of info here..... And probably get a set of proper gauges to check the system. Roger @ 928s R Us is the place to start.
Old May 13, 2012 | 11:43 PM
Dave928S's Avatar
Dave928S
Originally Posted by kenyawild
............... Have noticed that when I turn of the Ignition all is off but am still getting pressure through the injectors and loads of fuel still coming out? And flooding?
Any suggestions ?
marc
The system should hold a static pressure, but you shouldn't be getting fuel coming out the injectors with the system at rest. This could indicate a blocked up/dirty distributor head and plunger,or jammed plunger/air metering plate/mechanism, which is not allowing the head to shut fuel off to the injectors. If the system is clogged or varnished control and system pressures will probably be all over the place.
We probably need a bit more information to be able to help you though. How long has it been since the car ran? If it did run before when did this problem occur? What checks have you done so far? .. etc etc.
Provide as much information as you can, and then we can help you begin the process of elimination of potential problems.
Old May 14, 2012 | 12:48 AM
kenyawild's Avatar
kenyawild
HI Dave,
The car has not run for 5 years and am struggling with her, have no idea about before and will check the pressure plunger.
I have printed off some parts of manual.
regards
Marc
Old May 14, 2012 | 01:06 AM
Avar928's Avatar
Avar928
I somehow missed the "has spark" part . My bad
Old May 14, 2012 | 01:34 AM
Dave928S's Avatar
Dave928S
OK ... if it hasn't run for five years then it's very likely that the fuel system is varnished up, and you have all sorts of other issues, like corrosion, from the car sitting around for so long. The plunger I'm talking about is within the fuel distributor head and moves up and down to vary the pressure to the injectors, and may be gummed up after all this time. You should not pull the fuel distributor apart.
Here are a couple of threads on starting a car after many years left idle, with a some checklists of what to do first.
https://rennlist.com/forums/928-foru...-restored.html
https://rennlist.com/forums/928-foru...ree-years.html
Get back to us with further questions once you've read these, and as much of the workshop manual (WSM) as you can absorb; but you very first step with the fuel system will be to flush it entirely to get rid of old fuel and debris. There is a very strong chance that the lines running up to the front of the car are corroded internally and may be feeding debris to the distributor and causing some of your problem (and may need renewal).
The problem solving will need to be a methodical approach, but starting with a clean tank, flushed lines, flushed accumulator and pump, and a new filter ... in other words, everything in the circuit that delivers fuel to the motor and returns it to the tank needs to be clean. If that isn't done to start with you'll just end up chasing your tail. While you have all the flex hoses off you should also replace them as a good safety starting point as well.
Once the fuel delivery and return circuit is clean and functioning properly, then you can start to problem solve by taking control and system pressure readings, and go from there and rectify defects in the fuel metering system (WUR, fuel distributor, etc).
Old May 14, 2012 | 02:32 AM
jpitman2's Avatar
jpitman2
What Dave said! BTDT (Been There, Done That)! Come back when the above homework has all been done.
jp 83 Euro S AT 54k
Old May 14, 2012 | 04:32 AM
kenyawild's Avatar
kenyawild
ok great thanks!
Old May 14, 2012 | 07:49 AM
Dave928S's Avatar
Dave928S
As you do things, keep reporting back here, and we can make sure you're heading in the right direction. Got any more questions? ... just ask. It would be worth posting some pics of your car, including a few of the engine bay, so we can see what general condition the car is in. From the other threads you can also see that pics help a lot in diagnosis of problems.
Old May 14, 2012 | 08:12 AM
Mike Frye's Avatar
Mike Frye
Craic Head
What Dave said!
And also, you might want to change the thread title to something like:
Help!!! 1980 MY won't start after 5 year sleep
Or something like that. This way the rest of the OB masters (in addition to Dave928S) will know what kind of trouble you need help with. It will also help later on when others are searching the archives.
Good luck with it!
Old May 14, 2012 | 10:04 AM
depami's Avatar
depami
Very good advice, Dave, I'm just curious about the part in red. Is it some form of Pandora’s Box that will not go back together? Or, does disassembly cause damage or alter calibration? Etc.
Good luck KenyaWild, looks like you have a fun, challenging and frustrating project all wrapped up in one.
Old May 15, 2012 | 07:35 AM
Dave928S's Avatar
Dave928S
Originally Posted by depami
Very good advice, Dave, I'm just curious about the part in red. Is it some form of Pandora’s Box that will not go back together? Or, does disassembly cause damage or alter calibration? Etc.......
Hi Denny ... I posted not to pull the distributor apart because they can be very difficult to get back together leak free, and are easy to damage if you're not familiar with the workings and overhaul procedures. The OP needs to do do a lot of other things and tests first, and would want to be certain of an internal problem with the FD before even thinking about pulling it apart anyway.
They fall into the category of injectors, MAF's, and all the electronic bejeezus boxes, etc, etc, that are really best overhauled, cleaned, repaired and calibrated by experts .... but ... that's not to say that, like any of those things, they can't be done successfully by someone who has the skill and patience.
BTW ... +1 on what Mike said re another title for this thread, would help to draw advice from others who can help.
Old May 15, 2012 | 08:11 AM
kenyawild's Avatar
kenyawild
Default Help!!! 1980 MY won't start after 5 year sleep
Thanks for the advice,
I have found that the 2 fuel lines from the front(warm up control) of the have been inserted in the wrong places on the distributor(where they go into the pressure valve) The one that goes down the side next to throttle is kinked as they tried to make it fit! It makes me wonder if the injector tubes are in the correct sequence on the distributor as they are all out of shape? I cant find any diagrams of the positions? Do they run like the distributor as fire order.
Getting there slowly
Marc
