Rear hatch lock, broken actuator replacement?
Hi guys,
On the pic below, was wondering if #6 shown from a rear hatch upper lock hatch were replaceable individually.
![Name: image044.jpg
Size: 30.4 KB](https://rennlist.com/forums/attachments/928-forum/631718d1336691093-rear-hatch-lock-broken-actuator-replacement-image044.jpg)
The rest of the assembly is in great shape, it is an alarm unit but factory alarm is disabled.
That actuator # 6 is what broke. Can't unlock the hatch with the key.
Was considering just buying the newer lower hatch release part and vw motor to open from inside if I had to. Much cheaper than to buy a whole new lock assembly and have to rekey.
I swapped mine a couple of years ago, very straightforward once you get the part. Got mine from 928 int.
I wouldn’t rely 100% on the remote release always working when you need it.
did you swap just the actuator (part #6) or the whole lock cylinder assembly? Because I don’t want to swap the whole cylinder and have to use a different key
https://rennlist.com/forums/diy-928/...ne-strutt.html
Just the actuator. Used Dwayne excellent write up to take the mechanism apart, keep the key in the lock so nothing extra falls apart:
gazfish (04-23-2022)
I have seen the remote actuator fail because the nylon bush in the link has collapsed. I turned up a brass bush (cos I had the stock) - 5mm bore, 7mm OD, 5mm long; ground off the peened over cap, retained the link end with an M2screw and nylock nut. There is a pic here somewhere...
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
